RE: cooling head
You can put use large zip ties around the top fin on cooling head ,cut off the long strap once pulled tight..It will help..
But the city roll cage is best too use..yes your body does sit higher..But if you want the best protection use a roll cage..
Learn how to control your driving better...Yes things happen flip up side down ect.. Just my 2 cents worth....
