RE: Help CX2 problem
Are you using the stock Tx that came with your CX2? Please explain how you are trying to re-bind. Maybe you are doing something wrong. Do you have the bind plug inseted into the BATT port on the AR6100e when you try to bind? List the steps you take and the order.
If you are doing everything correctly and it still will not re-bind, check the batteries in your radio and try again.
