RCU Forums - View Single Post - Scratch Build - 29" Balsa Stepped Cat
Old 03-22-2008 | 01:03 PM
  #52
SV27dayton's Avatar
SV27dayton
Default RE: Scratch Build - 29" Balsa Stepped Cat
More progress on the balsa barge. First picture shows the sides after sanding down to the supports. I then used a template from the origninal stringers to cut the steps into the outside. A little more sanding and then glued the bottoms in place, more sanding. You get the idea. I'm real happy with it so far. THings will slow down as now I have to do the nose on the tunnel and the rear and I'm not sure how I'm going to do it. So more thinking. Starting to look like a boat now.
ID:	910438   Click image for larger version
ID:	910439   Click image for larger version
