RE: AFPD add on 1 problems
I believe this same error came up last week after a major, out to the case update of everything, while trying to do the same thing you are. It took some time to find the answer but turned out that the InstallShield file - 0701 - was
corrupted. To solve this problem in XP Pro I clicked Start and Run, typed in Explorer and expanded Local Disk C:\Program files\Common files\InstallShield\Professional\RunTime\0701. I deleted file 0701 file, and rebooted so that Windows
could rebuild the InstallShield file. I was then able to install updates 1 and 2, although update 2 Starflight was always able to be installed even with the corrupted update file.
A very strange situation that would certainly have popped up again with some install in the future. I was certainly hesitant to delete an InstallShield file, but it did work and AFPD is hummimg again. Hopefully you will be able to do the same
Good luck.
Stew
i
