RCU Forums - View Single Post - Plans or kit :Tigertail IV??
Old 03-22-2008 | 04:23 PM
  #163
ramcfarland's Avatar
ramcfarland
My Feedback: (44)
Default RE: Plans or kit :Tigertail IV??
Hello all------
Well again I have heard of this method ,however, I achieve nearly complete impregnation (I've done better[8D])of the glass and >>>>>>>on to and into the 'balsa wood wing skins,' using New playing cards frequently replaced as you want to have a uniform pressure on the surface as you spread the line of mixed resin you poured along the section you dare try and glass before the resin sets up;for peace of mind common sense prevails:glass at temperatures not exceeding 75 degree (during the application process.) Now depending on environment you could well do the second easy and very quick coat of FTE Z Poxy Resin and quite possibly be priming/filling[:-] the same day. You know:got the energy so use it--
Hope this is useful as it takes time out from building and flying...
ID:	910570   Click image for larger version
ID:	910571   Click image for larger version
ID:	910572   Click image for larger version
ID:	910573   Click image for larger version
ID:	910574   Click image for larger version
ID:	910575   Click image for larger version
ID:	910576   Click image for larger version
