RE: DL-50 engine
The bad carbs were around Feb of 07. If you have a bad one, it will die as soon as it is throttled up. You can either fix the one you have by using a tiny drill bit to drill out the high speed needle hole, or possibly contact DLusa.net and see if they will still replace them.
