RE: OFFICIAL HYPER 7 THREAD
I'm doing a PBS conversion on my Hyper 7 TQ Kit. I followed all the directions that came with my conversion package. It said that there should be 2 threads showing on the lower arms in the rear when you screw in the pillow balls if you are using the hyper rims which I am but if not you should cut 3mm off the ball stud if using other types of rims. I am doing the rear conversion at the moment and with everything mounted looking from behind, the rims tilt in at the top a bunch like this--> /---\ and the rear dogbones are about to fall out. Are the TQ and PBS top rear arms and dogbones the same length?? I can screw the pillow balls in further and it fixes the problem, should I cut some off the studs to allow it to screw in the arm without bottoming out?? How much toe in/out should there be on the front/rear?? camber front/rear?? what should the width of the rear and front be when measuring from the outside edge of the rim to the other?? Sorry for the long post, thanks in advance for your help.. I know its probably something simple thats why I'm asking before I screw something up...
