RCU Forums - View Single Post - LT-40 Taildragger balance
Old 03-23-2008 | 06:56 AM
Bill Diedrich's Avatar
Bill Diedrich
Default RE: LT-40 Taildragger balance
I recently converted my Lt-40 to tail-dragger, man what a diffence, installed a seperate servo for
steering tail wheel and ran small Sullivan cables to a springing tail wheel assembly. I would advise
that you align the center of the axle of the main gear with the leading edge of the wing, as I fly
from a grass strip and didn't want to nose over. If you do install the pull-pull cables as I did you will
have to cut a section out of the bottom of the fuselage balsa and re-glue it and re-cover it when done.
Will post pics of my conversion later today.
Balance point is same as tri-gear set up.
