RE: HiTec Dig Servo Programmer Charge Jack Problem?
It seems the charge jack is diode protected, just like many older Tx's, so the charger cannot detect any voltage at the terminals, but it can be charged by a "dumb" charger like a trickle wall charger. I just need to disable/override the charger low voltage detection to make it work.
As for the servo driving not working - Oops - It works fine when the servo is plugged into the correct port! DOH!
