HiTec Dig Servo Programmer Charge Jack Problem?
ON, CANADA
I just opened the box on a new Hitec servo programmer and connected my trusty Thunder Power Peak charger to top up the onboard NiCd pack. (using the charge jack/port on the programmer) The charger thinks the voltage is virtually zero and won't charge. So does my volt meter.
So I opened it up to check the pack voltage directly - it's 4.9 v! So now I'm wondering if I have a defective unit OR it's designed that way with some kind of diode in the charge circuit. Anyone know?
ORIGINAL: MikeAndersonCA
WA
It is a 4.8 V pack. Directions say to use a slow charge on it. I got mine and plugged it into wall charger over night, and no problems.
ON, CANADA
It seems the charge jack is diode protected, just like many older Tx's, so the charger cannot detect any voltage at the terminals, but it can be charged by a "dumb" charger like a trickle wall charger. I just need to disable/override the charger low voltage detection to make it work.
As for the servo driving not working - Oops - It works fine when the servo is plugged into the correct port! DOH!
My Feedback: (87)
It will not charge with a peak-detecting charger since the HFP-10 is unfortunately diode protected, just like the Hitec transmitters. In my opinion, this is a dumb, antiquated design, but I deal with it by charging it with a "dumb" charger like an Accucycle or similar which charge at C/10 rates.
If I am in a hurry, I unscrew the end panel and remove the battery to fast charge the battery removed from the programmer. I replaced the 600 mah battery with a 2000mah NiMH to improve my run time with it.
