RCU Forums - View Single Post - question for the elctomagicians
Old 03-23-2008 | 04:49 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: question for the elctomagicians
ORIGINAL: 971wright
Hi Guys Is it posible to wire a luxeon K2 led for muzzle flash if so what is required i was thinking of removing it from holder and fitting in muzzle brake. or is not posible to remove from the holder the flash from one of these is supposed to be ten times brighter than ultrabrirght led or is it not posible see site http://www.ultraleds.co.uk/05027-pw1...ns-p-1377.html
regards pete
Pete,
If you are talking about using it on a HL, although is does not give you the exact voltage on the product description sheet two things stand out! One is takes 1500 mili amps or 1.5 amps you won't get that off of your Heng Long board and th unit requires a heat sink, it is not a holder is is a heatsink to disipate the heat with that much current in such a small device!
The Blitz
