RE: question for the elctomagicians
Hi Darkith the k2 was designed for mobile phone flash for the new generation phones with 4megapixal to give better flash they are made by Philips and throw the light better than earlier flashes also know used in flashlights .I was thinking of using 3 aaa batteries for power source and activating with a micro switch or read switch the reason I thought of these is the size its possible to fit it in the muzzle brake and still allow it to fire BBs don’t no how big the flash unit is from disposable camera but its a good idea and cheap. My other option is 3 mm ultra bright led this will go in the muzzle brake but not as bright as the K2. Just going through the possibilities before making my mind up which to fit. This going to go in my BB firing recoiling gun in my tiger. Then I have to work out how to make it smoke after firing.
samarkh yes thats an option but was trying to keep my BBgun working already got it to recoil and fire i have these daft ideas then try to find the solution i will probably try 3mm ultra bright led first as these or only 90 p just to see if i can time the muzzle flash to the BB firing and recoil but iwould like a big flash like the tamiyas .
best regards thanks for your input Pete
