RCU Forums - View Single Post - Toro 25 and Ryobi 31-same troubles!!
Old 03-24-2008 | 07:25 PM
buzzardbait48's Avatar
buzzardbait48
My Feedback: (7)
Default RE: Toro 25 and Ryobi 31-same troubles!!
Craig,
I have had a Toro 25CC for going on three years. I had the same problem you did. I was told to solder a brass tube
on the other side of the Walbro Carb. (opposite side of the fuel in line) There is a small hole already there. Put a
piece of gas tubing on the new brass tube and put it back into your fuse. That worked for me. Also you can buy a
Velosity Stack for your Walbro Carb.
Louie, Louie
