RCU Forums - View Single Post - Byron Wedell Williams Racer Build
Old 03-24-2008 | 09:30 PM
Rocketman612's Avatar
Rocketman612
My Feedback: (85)
Default RE: Byron Wedell Williams Racer Build
Well the build is progressing. Got off track with spring Honey Do's [&o]
The Horizontal Stab is pretty straightforward. The Keel components are butt glued then the TE 1/2 in balsa followed with the leading edge balsa parts. I glued the 4in wide center balsa after marking the cut line for the LE section. Cap strips added. I just need to add the 1/8 ply supports for the stab flying wires.
Pete
ID:	912779   Click image for larger version
ID:	912780   Click image for larger version
ID:	912781   Click image for larger version
ID:	912782   Click image for larger version
ID:	912783   Click image for larger version
ID:	912784   Click image for larger version
