RE: Toro 25 and Ryobi 31-same troubles!!
I can't see where the blue line is going , but I'm guessing it goes to the plate that has a little hole in it? And then run
a line into the fuse where it's out of the wind? So if I tap this hole and put in a little nipple like on the 40 size mufflers
and stik a line on it and run it into the fuse I should be OK? Is that right? Craig
