ORIGINAL: BillHarris
It may be do-able. I have a Brison 4.8 Twin that I'd like to use it with, and as fate would have it, the spacing between two of the mounting bolts is 78mm ( the same as on the MVVS bracket). Are the MVVS mounts available thru a USA dealer, or should I ping Pe R?
--Bill
Bill
The Evolution engines which are available in the US are a badged MVVS, I would think therefore that you should be able to get the mounts from an Evolution stockist.
Mike
