RCU Forums - View Single Post - Plans or kit :Tigertail IV??
Old 03-25-2008 | 03:32 PM
  #167
ramcfarland's Avatar
ramcfarland
My Feedback: (44)
Default RE: Plans or kit :Tigertail IV??
Also I meant to post some words and pictures of a technique I tried to ensure the 'fit' between the Tiger tail IVs fuselage and wing remain close,as in no /minimal gap. The technique I used was simple take the fuselage as the reference to cut and trim a piece of WAXED PAPER to fit the fuselages wing saddle EXACTLY. Next go glass your wing (helps to have enough glass to do both sides of the wing) un like me ...anyway once you have glassed the top wing surfaces wait for the 'Epoxy finishing/surfacing resin to become "just a bit tacky to the touch,'NOW invert the model (more fun in flight) and lay down your pre cut wax paper " fitting along the out side perimeter of the wing saddle," now proceed to bolt on the wing ensuring the bolts are tight, now flipping the airframe back over should reveal no protruding wax paper past the wing saddle...Alow resin to cure and un bolt wing.
To be continued
