RCU Forums - View Single Post - Will it go faster?
Old 03-25-2008 | 08:38 PM
RC_Bob
Default RE: Will it go faster?
but it may be illegal. The FCC does not allow 72mHz radios to be used on surface models, nor can 75 mHz radios be used in planes.
That's what I meant to say[sm=rolleyes.gif]
Also brendon about those motors you mentioned. We're not sure if they'll work or not until we know what the specs are of each motor type. The ones that you said you would cut off and the one that you plan to buy. Do you plan to use those for an airplane prop(cuz this sounds like an airboat project that we're talkin about) or the water props that come with the motor?
