RCU Forums - View Single Post - Diffs & Dogbones.....
Old 03-26-2008 | 08:21 AM
BudBud's Avatar
BudBud
Default RE: Diffs & Dogbones.....
ORIGINAL: burnchassis3
Its not the locked diffs!
Its not the engine!
its the dogbones!
I ran a Collari 32,Force 32 STS 30...those engines are very torquey.
I have had locked diffs for a long time front ,and rears on both savages.
Get these CVDs
http://cgi.ebay.com/Hpi-Savage-21-25...QQcmdZViewItem
I have not burned up a drive cup since I changed to those,and I have only broken 2 axle cvds in about 16 gallons of fuel.
You WILL notice a difference in your ride after you put those on.
BTW the 2 that did break the seller replaced no questions asked.
CS
Thanks for that link! I have a set of those and cannot keep the pins in the joints, I keep shearing them off. Maybe the seller can steer me into a good set of pins or replacements. I have been making my own pins by cutting off a longer pin of the same diameter. Out of frustration, I went back to the dogbones. BB
