trx problems
when its about to run out of gas it should rev high cause its getting less fuel and thus leaning itself out. try to prevent that.
when you come in for a pit stop and try to fire it back up and it wont fire, maybe your too lean and thus the engine is too hot.
and on the part where you have to put fuel in the carb to start it, i have a traxxas with a trx on it and my problem was with the plunger on the gas tank.
i dont knwo if thats your problem, but if your not getting fuel into the carb and you have to drip it in there it might just be caused by that.
you can take the plunger out and the just cover the tip of the exhaust and turn the engine over to get the fuel up into the carb.
just pull the plunger partout and cut it off with some heavy duty dykes and the open the cap and pull out the rest of the pieces. then put a screw in the hole from the plunger.
