RE: Sig Kougar Build
jollyroger...It wouldn't be that hard to do with the wing covered. I did the same modification on my Alpha 40 Trainer, which was an ARF. That was a little bit easier since it had wing spars instead of solid foam, fishing the wiring and mounting was simple.
Thanks for the kudos.
