RCU Forums - View Single Post - Engine will not start????????????????????????
Old 03-30-2008 | 01:43 PM
125cchyperman
Default RE: Engine will not start????????????????????????
I had this problem once with a ABN engine, the Nickel plating had actually peeled off around the exhaust port and also around the transfer ports. It would spit fuel out the carb and would also spit a ton of fuel out the carb. Would rarely ever run, and when it did it would only run for a secound or two and then shut off, try and check the sleeve. This could be your problem.
