RCU Forums - View Single Post - Seamaster 40F
Old 03-31-2008 | 08:27 AM
  #33
ekfinch
Default RE: Seamaster 40F
Joe, you have a lot of seamasters in the club. Our club is in Gainesville, Ga, which Lake Lanier was built within and around. Some of the city was even flooded when they built the dam. But, most of the flyers use floats on their planes and do not have the Seamaster. With what you and everyone else has said about the plane, I am a little surprised there aren't more in the club.
I do have another question. Did you shim your engine up on the the engine mount? I read somewhere that it tends to pull when the throttle is cut because the engine is pitched down a little. They suggested shimming the engine up about 2degrees. If I did that what would you use for a shim?
THanks,
Keith
