RE: OLD Giles 202 - Help needed!!!
Two rudder servos is massive over kill if your using an 8611, 5955, or 8711. Tail mounting one or both works just fine and is easy to do. That's how I do most of the Wild Hare planes I have to offset nose weight. Only two so far have had a pull-pull, and then only for balance reasons. It's also more positive than a pull-pull. They fit in the holes provided for them with no problem. You may find that using only one works out a lot better for weight and balance as well.
