ORIGINAL: crazyf3a
HI
Yesterday I measured my wings. Only the wings. Not the difference betwenn Elev. and Wing. It has me interested. Is there a difference between the left and the right wing.
YES, the wings have 1/4 degree difference. (Measured and calculated). The setting angle difference is 1/4 degrees between Elevator and wings, and I think the difference between the wing is to much. I will not always grumble, but it annoys me again. That probably means working on the weekend. The weather is too bad to fly. So I go into the plant room (basement).
Would it not be better to assemble an Wing adjuster. My opinion is there a wing adjustment from the factory to install. Then you could also make the aileron to zero. This is only my opinion. Criticism is good if it is positive.
Have a nice day.
andreas
Did the Right wing, (Starboard Wing) have a greater angle of attack than the left?
