RE: Zen powered Rio51. Short video
mauian, how did you set your outer strut assembly? Can you slide your shaft in and out 1/4 inch or so? I'm getting too much wear at the soldered on collar or washer on the shaft. Did you push your inner housing all the way in before you tightened down? I'm a little confused with the slight difference in the Zen vs the Fugi spacing at the drive.
