RE: one quick question
i did the paper trick with my volcano and found the easiest way to get it is to make sure it's long enuff and get it to go all the way around the clutch teeth until it touches again and snug the screws for the engine mounts pull the paper out and check all the way around and it should be good as long as there isn't too much in the tight spots. thats my 2 cents.
