RE: Beaver question
Unless you are planning on totally rebuilding the plane, probably not going to happen. This plane was designed for electric, and as such is not designed to handle the intense vibrations you will get from a glo engine. The firewall for instance is about half as thick as it would be for a glo mount. I am currently assembling this plane to hang up in my store, but will use the power 25 motor as I will not be setting it up for floats.
