RCU Forums - View Single Post - Sig Kougar CG
Old 04-03-2008 | 09:15 AM
MikeL@Sig
Default RE: Sig Kougar CG
Hi i3dm,
Here are the factory specs,
Set Up Specifications English Metric Directions
Elevator 3/8 inch 9.5 mm Up and Down
Rudder 1 1/2 inch 38 mm Right and Left
Ailerons 1/4 inch 6.4 mm Up and Down
Center of Gravity 1/2 inch 13 mm Back from tip
Dihedral 1 inch 25.4 mm Pre Wing Panel
Incidence +0 degree wing, 0 degree stabilizer
Engine Offset 0 degree down, 0 degree right
Happy Landings
Mike
