 Sig Kougar CG >
Sig Kougar CG
Sig Kougar CG
Old 04-02-2008 | 12:19 PM
My Feedback: (51)
Default Sig Kougar CG
Hello guys,
Does anyone know the correct SG for the Kougar by SIG (wood kit) ?
Old 04-02-2008 | 11:46 PM
jrcaster's Avatar
Default RE: Sig Kougar CG
According to the manual it is between the leading edge at the wing tip and 1/2 inch back at the wing tip.
That makes it hard to visualize but I think it is at the thickest point at the wing root, or basically at the front edge of the servo mount.
Old 04-03-2008 | 09:15 AM
Hi i3dm,
Here are the factory specs,
Set Up Specifications English Metric Directions
Elevator 3/8 inch 9.5 mm Up and Down
Rudder 1 1/2 inch 38 mm Right and Left
Ailerons 1/4 inch 6.4 mm Up and Down
Center of Gravity 1/2 inch 13 mm Back from tip
Dihedral 1 inch 25.4 mm Pre Wing Panel
Incidence +0 degree wing, 0 degree stabilizer
Engine Offset 0 degree down, 0 degree right
Happy Landings
Mike
Old 04-03-2008 | 11:05 AM
ORIGINAL: i3dm
Hello guys,
Does the comment mean that the wing is not foam?
Bill
