RCU Forums - View Single Post - 2.4 issues with gear sequencers??
Old 04-03-2008 | 12:11 PM
  #31
dbarrym's Avatar
dbarrym
My Feedback: (47)
Default RE: 2.4 issues with gear sequencers??
ORIGINAL: johangr
Hi guys,
Need to know whether it is at all possible to restrict your servo movement through a gear and door sequencer. I have the EMS Gear & Door Sequencer, but if I program my radio to move the servo less than 100%, this setting is not transferred to the gear servo. This poses another problem. If this setting can be transferred, it's most likely going to affect both the gear and door channels on the sequencer? Any ideas or suggestions?
The Jetronic sequencer behaves the same, you need to go "old school" and use a servo arm that is the correct length and geometry to get the motion you need. Rather than reduce throw, just use a shorter servo arm, and if needed, offset the arm on the servo to restrict output motion toward the end of the servo rotation/arc.
barry
