RE: M148 flat agent
I am using the "fast" hardener. Not sure how fast it is supposed to dry to touch, but 1 hour later it was still somewhat wet. I honestly think that I did not mix the flattening agent properly and I merely poured solvent into the clear/hardener mix.
I only have two tables to work with, so I rely on shooting the bottom fo the fuse, wings, stabs first, let it dry and then flip them over to shoot the top side.
How long should it take to cure?
