RCU Forums - View Single Post - Overheating battery
Old 04-03-2008 | 07:38 PM
Superbike1
Default Overheating battery
Hey guys I am new to the battery and power side of the house and I have a home built foam stealth plane like the ones on ********. I am using a stock battery pack from a parkzone typhoon with the stock motor and speed control. The speed control is an programable 20 amp. Today I was flying at full throttle for about 4 min and then I brought it in for a landing and when I went to take out the battery pack, It was so hot the shrink wrap had melted and the velcro glue which I use to keep it in place had come loose. Normally this motor in a typhoon is geared and I run it direct shaft to 9x4 pusher propeller. Is it pulling to many amps because of the way I am running it? I never had this problem in the typhoon. I don't currently have an amp meter to see what is going on but my speed control and the motor are both barely warm when I fly it. I do have a small air intake to aid in cooling the speed control and the battery. Any suggestions as to what is going on? Thanks for any information ahead of time. Dean
