RCU Forums - View Single Post - Fuel Tank?
Thread: Fuel Tank?
Old 04-04-2008 | 03:29 AM
Lou Crane
Default RE: Fuel Tank?
Doug,
If you are into a bit of experimenting, you can convert a plastic film can to about a 1 fluid ounce tank, or an amber colored pill bottle for 2 fluid ounces. I prefer the clear amber pill bottles, since you can see where the inside tubes go. The pill botle cap threads on; the film cans tops snap on. Both are fuel proof and secure enough. The childproof outer cap on the pill bottles can be nipped off if you use a diagonal cutting pliers carefully. ...Saves about 1/4 the weight of the tank...
Simplest way with these would be to drill into the caps aboput 3/32", then use an awl to stretch the hole to a tight fit on 1/8" brass or preferably copper tube. With the cap and tube clean, a dab of J-B Weld (standard, i.e., slow curing) wiped around just the area the metal pierces the cap secures the tubes. One tube for vet; one tube for filling and feeding the engine.
The metal vent tube should be bent to touch the top of the tank, so you get a more complete fill. The fuel pickup tube only needs enough length in metal to allow a (silicone, e.g,) fuel tube to reach near the back end of the "can" and the plastic fuel lines usually have enough curve that you can position it so it rests on the "outer" wall. These are neat tanks for CL because you can rotate them to improve feed, etc. Also light, cheap and easily available.
Small metal tanks are available, of course. I think... You should carry 1 fl oz or more of fuel. You don't have to fill it completely if you prefer a shorter flight time.
Best of Luck!
