RCU Forums - View Single Post - senior telemaster engine?????
Old 04-04-2008 | 11:10 AM
Bigshark's Avatar
Bigshark
Default RE: senior telemaster engine?????
I run a Tower 75 two stroke on the Telemaster which is pretty far towards overkill. It will handle the weight of a gasser fine. Mine flys better with some payload. One thing I'd recommend is to sheet the fuse. The tail feathers on mine flutter like crazy on the ground in the prop wash at full throttle. The stick built fuze is a bit flimsy......
