RCU Forums - View Single Post - M148 flat agent
Old 04-04-2008 | 03:55 PM
FalconWings's Avatar
FalconWings
My Feedback: (57)
Default RE: M148 flat agent
ORIGINAL: drdoom
Did you find those little indentions at the ordinance mounting points, on the bottom of the wing?
Yes, I found them. Two indentations per pylon.
I drilled only one indentation as a pilot hole, clocked the pylon and then match drilled the second hole. The indentations do not match the holes for the bolts in the pylon, but they are close enough thousgh.
The HS-5125MG's fit perfectly in the wing pocket.
I have a Yellow F-16 cockpit laying around , I will try to install it. This is a full cockpit with all the instruments and gauges. I will modify the equipment tray so that it lies closer to the bottom of the fuse. Since I do not install anything underneath I can get it very close to the bottom. The Yellow cockpit has a large and deep "tub", so the equipment tray location has to be modified. As a matter of fact, we don't need no stinking tray.
Do you know the capacity of the main tanks? They look big! Did you use a 3rd tank above the inlet?
David
