I lucked into the hardware I needed to finish up this project;now all I need is 4 high end JR servos I will go with a couple 8611As for pull pull rudder and and single center mounted 8611A with C.F. push rod set up from
www.Centralhobbies.com- handles the elevator (worked great in the first TTIV.)...before I sifted it through the trees what a SOUND[X(] ,for wing mounted aileron servos any thoughts people.[:-]
Well 'Finishing resin is curing overnight and then a bit of out of doors sanding...
