RCU Forums - View Single Post - Piston Damage
Old 04-05-2008 | 07:49 AM
pe reivers
Default RE: Piston Damage
The engine is repairable, but at a cost.
ake it apart and check. You will probably find that some small metal particle has parted from where it belonged, probably a bearing cage as some posters before mentioned.
It's a good study object. Take it apart and learn, then prop it up as a paper weight to remind you of timely maintenance for your engines.
