Piston Damage
Old 05-14-2008 | 01:34 AM
  #126
plugin's Avatar
Default RE: Piston Damage
I replaced the bearings with plastic cage ones which may eventually reduce fatigue. Or so I figure. Front one is NSK and the rear one is NTN, I got these from a local bearings store (Bogota, Colombia) and I sure hope they come from a different batch which is likely because they have different cages.
At least I'll be using the culprit or it's victim, the piston, as a brand new keychain.
Old 05-14-2008 | 02:46 AM
  #127
DarZeelon's Avatar
PropTop,
I also believe the relationship is true in some cases... The causal affect is one-way, i.e. bearing damage shrapnel will score the sleeve/piston, but the thin flakes of nickel are unlikely to make the rear bearing 'go south'...
...But I have seen enough junked bearings in OS engines, in which the P+S were immaculate.
Bearing replacement was the only repair necessary.
I wish you luck, Plugin... NSK should good.
Old 05-14-2008 | 06:53 AM
  #128
plugin's Avatar
It says Japan on the front shield. but I mistyped the name on my previous post, they are NSK.
Old 05-14-2008 | 07:15 AM
  #129
Sport_Pilot's Avatar
I donno, but nickel is very hard.
Old 05-14-2008 | 07:53 AM
  #130
DarZeelon's Avatar
ORIGINAL: Sport_Pilot
Is it, Hugh?
Please see the Rockwell C column [link=http://www.metal-mart.com/Guides/Hardness_Nickel.htm]here[/link], for nickel alloys.
Also the bottom table [link=http://www.steelmedia.com/chrome-steel-balls.htm]here[/link], for AISI 52100 and EN 31 bearing steels.
The flaked nickel particles would be pulverized...
For that matter, chromium (true ABC) has a Rockwell C hardness rating of 68-74...
Old 05-14-2008 | 09:50 AM
  #131
But that doesn't flake. Though nickle is softer, I think it may be hard enough to do some damage, maybe not right away. All it really has to do is jam up the balls so that they slide instead of roll. After a time this will ruin a bearing.
Old 05-14-2008 | 10:57 AM
  #132
DarZeelon's Avatar
But that doesn't flake. Though nickel is softer, I think it may be hard enough to do some damage, maybe not right away. All it really has to do is jam up the balls so that they slide instead of roll. After a time this will ruin a bearing.
True, Hugh.
Chromium is much less prone to flaking off, because its bond to the brass/aluminium sleeve is very strong...
Each of its 'islets' is sitting very firmly on the surface.
The damage you describe with nickel is possible in theory, but usually, flaked nickel is not carried back into the crankcase, but rather spewed out the exhaust, or lodged between the piston and the sleeve...
And yes, sliding balls in bearings will noticeably shorten their term...
Old 05-14-2008 | 11:53 AM
  #133
plugin's Avatar
Now that you're on the subject, what about aluminum shards that get torn of the crankcase, are those prone to cause a lot of damage or are they considerably less harmful than pieces of the bearings?
Old 05-14-2008 | 03:03 PM
  #134
DarZeelon's Avatar
Plugin,
Since in most engines aluminium parts do not participate in direct mechanical work, against other parts (except the very hard high-silicon piston), it is quite unlikely for aluminium parts to start floating around in the engine.
The back-plate may come into occasional contact with the crank-pin, but this will at most cause a swirl-pattern on it - not major shard separation...
Old 05-14-2008 | 03:25 PM
  #135
plugin's Avatar
I see, I'm just wondering because from the pictures I've seen, when a little piece of bearing floats around the engine it dents and scratches everything like in Bad Tooth's engine. I was just wondering in the hypothetical case in which shards of aluminum where to go around the engine, what sort of damage could one expect? Could they contribute to damage the bearings even more?
Old 05-14-2008 | 03:28 PM
  #136
DarZeelon's Avatar
If an aluminium shard is caught in the bearing, it will prevent a ball from rolling, causing it to skid instead...
This can be damaging to the bearing.
Old 05-14-2008 | 04:07 PM
  #137
Banned
ORIGINAL: DarZeelon
Is it, Hugh?
Actually, the nickel deposited by the electroless process *is* a lot harder than regular nickel, that's because it contains relatively high levels of phosphorus it's not just pure nickel (which is much softer).
Old 05-14-2008 | 04:40 PM
  #138
Bad Tooth's Avatar
My Feedback: (10)
Plugin, do you have some pictures to share? Now you have a fun engine rebuild project
Old 05-14-2008 | 09:17 PM
  #139
My Feedback: (27)
Keeping this in context, remember that the engine will be turning 11-15,000 rpm and is also very hot.....one little thing goes wrong and mayhem happens. Actually I marvel how strong most of our engines are.
Many are operated by guys who don't know or care much about the engine until it fails and then find fault. Some engines are more prone to fail than others and their faults will surface in short order. A little knowledge and care go a long way.
Old 05-14-2008 | 11:20 PM
  #140
DarZeelon's Avatar
ORIGINAL: XJet
Actually, Bruce, it is actually medium phosphorus electroless nickel that can be heat-treated up to 68 Rockwell C... High phosphorus nickel offers superior corrosion resistance, when applied to steel.
I do not know what after-treatment OS ABN/ABL sleeves undergo, after they are nickel-coated... Do you?
Old 05-15-2008 | 02:32 AM
  #141
Banned
I don't know what OS are doing, but the ENP I'm using here is very hard and used as a bearing-surface in a couple of the assemblies I make. Even a very thin layer provides excellent wear properties is "harder" than austenitic stainless steel.
