RE: SNFF 0406
Hey nothing wrong with Saturday Night Foto Fun
I got my Panzer IV , and after making sure everyhing worked. I gutted the wiring and rewired it. Took out the smoker and added an I pod speaker.
I moved the on off switch to the back and hid under that thingamajigi on the back, You slide it left or right to turn on the tank. I opened up a front hatch and mounted the charging jack under it.
Added a 7.5 cm cannon, ran the IR wiring and installed a IR emitter in the mantlet. Can't see it because it has been masked off and painted over
I then painted it metalic, which will then get a coat of primer followed by Panzer Gray.
More to follow
