ORIGINAL: Pat Roy
Here's a little known tidbit. Wild Hare will be marketing a small "hop up" kit for this engine pretty soon that should easily put it on a par power wise with the DL 50. It will be an easy install and make the 3mm 53 an incredible value.
Thanks for the info .... was not aware of that. I'm guessing a new reed assembly as that looks to be the main restriction on the 3mm.
