RCU Forums - View Single Post - Does anyone know the specs for a WT463 or WT391?
Old 04-06-2008 | 10:32 AM
tim220225's Avatar
tim220225
Default RE: Does anyone know the specs for a WT463?
That one has an 11.11mm venturi and should work fine. Are these carbs NOS or used? If they are used you need to add in the cost of a rebuild kit. Sometimes you are better off buying new.
