RCU Forums - View Single Post - cavitation!!!!
Old 04-07-2008 | 12:22 AM
hard 2 find a username
Default RE: cavitation!!!!
ORIGINAL: joccee
the prop is too small...I think people are using 37-45mm props on their SV's
so would you recommend a sv27 3blade plastic prop? or steel??
if so what size mm??? i dont know if this is the info you need, but it weighs 1.6kg and is 20inches from tip 2 transom, 25inches including hardware.
thanks guys, i really want to get her running
Corey.
