RE: StuG IIIG build thread
The Hull is now back up and running - see picture - although the boards and battery etc are just "thrown" in. The boards are in ziplock bags to stop them shorting out on any other bits of metal (or each other). The result of painful experience!
I've relieved the inner wall to miss the motor shaft - you only need to do this if the walls are thicker than standard. See also the relief for the return roller mounts.
By following the plans slavishly I have actually built a very early G, with the short side panniers. It's not what I was planning to do so I have extended them. (Doh!)
Jo
