RCU Forums - View Single Post - StuG IIIG build thread
Old 04-07-2008 | 01:33 AM
  #31
jom's Avatar
jom
Default RE: StuG IIIG build thread
Weld representation - I decided to use a temperature controlled soldering iron (it's an old cheap one, cunningly voltage limited through a light dimmer). It has a copper bit which has been filed to a chisel point about 2.5mm wide.
The light dimmer doesn't seem to work at the moment so I resorted to turning the iron on and off - use a bit of scrap plastic, get the iron hot enough to just melt the plastic and then turn it off and use it on the tank body. once it stops making an impression turn it on and repeat the process.
It pulls up a lot of plastic which looks scrappy, but after sanding it looks good - see the welds on the engine cover.
Also added the strip of armour under the mantlet.
Jo
ID:	923881   Click image for larger version
ID:	923882   Click image for larger version
ID:	923883   Click image for larger version
