RE: cavitation!!!!
Hi N.H.Schmidt
im at work at the moment, but im almost 100% sure that my shaft is 1/8 is this ok??
that is just the setup that the bloke at the boat hobby store showed me to use when i took the hull in 2 the shop.
he drew a quick sketch and gave me that shaft, prop, strut and rudder assembly, he just said i will need 2 make something 2 hold the strut in place, which is the 2 L shaped bits aluminum you can see holding everything together.
will this setup still work?? or will i need 2 try and make a new 1?
problem is theres no room left in the hull!!
it doesnt help the fact thats its a straight shaft not a flex[:'(]
thanks,
Corey
