RE: YS 63s priming problems
Put a little pressure in the tank to help get it started when you are fueling. About 2-4 extra cranks on a hand pump will do the trick... Then seal it up. This way when the regulaotr opens the tnak already has a little pressure in it.
Next is check the fuel filter and see if its partially blocked....
Troy Newman
Team YS
