Sorry for a bit of a delay. Im back to building now i really want to fly so have to get stuck in and get it done. Quick update on where im at, the wing is pretty much finished with just sanding and filling needed got the second aileron half built witch i will get done tomorrow. The elevators halves have been epoxied together just need to put the cap strip on it as the joiner is thinner than the elevators. i still need to put the triangle stock on all the surfaces and the opposite trailing edges. this is a nice touch witch allows the surfaces to have massive throws without any binding ( will look like this ><
. I have cut the 2 hatches out and put the rear lip on just have to put the strengthening strips on under it. Will get the tube drilled and cut and run a draw cable though for the servo wires during the week. Hopefully be ready to glue the thing together by nexted Wednesday as that will be the day dad has off work to help with it. The task of gluing it together looks a bit daunting but dont think it will be to bad, but just want to have dads assistance there when i do it as i know its a critical stage.
