RCU Forums - View Single Post - CG and Lateral Balancing
Old 04-08-2008 | 12:24 PM
dolphinsnut
Default CG and Lateral Balancing
Hello guys,
I have a RTF Hobbico Superstar MKII trainer. I recently read and I forget where (old age kicking in !!) about trimming.
With CG balancing what can I use to balance the plane ? Where do I put the weight and how should I attach it so not would damage anything inside the plane ? (I guess I can use lead weight's ?)
I also read briefly about lateral balancing. I guess I would balance the fin and I have my son hold the prop to check the balance here, right ?
But, if the the plane tilts, can somebody suggest how to fix the balance on the wing (from what I have read) if it tilts one way or the other ?
Thanks All
