What kind of difference will I get if I put the stock 3 blade prop back on?
Right now there is some kind of 2 blade prop on there. I wish I had more time with it,I wantedt o mess around with the trim tab's, I went fairly well but as you got faster it would tend to bounce up and down then I let off so it wouldnt flip,but it did anyway
Would bending down the trim tabs a bit "towards the water" would this make it stay flater in the water and take the bounce out at high speeds?
